Tagged: 2022 R1, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThere is a limit to the file size you can open with the Ansys Viewer. The limit is 2GB. This is the uncompressed size of the AVZ file.
