Tagged: 19, General, mechanical, spaceclaim, structural-mechanics
April 5, 2023 at 2:32 pm
FAQ
ParticipantProblem Description: I’m currently working on a curvy model in SCDM. SCDM is set to the highest rendering quality and shows reasonable rendering. However, in Mechanical, the rendering is very choppy for that model. I opened the same model in DM and set the Facet Quality therein to its highest setting. I then opened it in Mechanical and found much better rendering than when imported from SCDM. So it looks like the high rendering setting in SCDM is not carrying downstream to Mechanical. IS this the case. Answer: The rendering quality does not carry over from SCDM to WB Mechanical currently.
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/Ansys-Cloud.jpeg)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Optical-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Geko_Video-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/EnSight_PP.webp)
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
