Is it possible to use the Multicomponent Energy Diffusion formulation in the Enthalpy equation when an Algebraic Equation for the species is defined?
August 25, 2023 at 12:15 pm
SolutionParticipantYes. This is possible with the steps described in the attached description.
1. 2048529.zip
2. 2048529_MED_algeq.pdf
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
