May 25, 2023 at 7:29 am
FAQParticipantYes it is: -> Select “Preferences” from Project tree menu (usually on the left side of Savant GUI); -> In the “Preferences Properties” panel below set as true “Enable Multi-Threaded Computation” option; -> Select the maximum number of threads. These settings require at least one HPC license.
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
