General
General
Is it possible to run a Topology Optimization case with multiple load cases, whether its with multiple systems or multiple load steps?
    • FAQFAQ
      Participant
      Yes, but the geometry and model cells need to be linked (i.e. same geom, same mesh). The topology optimization objectives for each can then have weightings applied as desired.
