Is it possible to reproduce the simulation results from the build-in Small Droplet Model for Heat Transfer?
March 17, 2023 at 1:11 pm
SolutionParticipantThe Droplet Condensation Model is useful for situations where a dry (or near-saturation) two-phase flow undergoes rapid pressure reduction leading to nucleation and subsequent droplet condensation. There are build-in models available describing the mass and heat transfer between phases. How to reproduce the ANSYS CFX Solver behavior when using a user-defined Small Droplet Model for the Heat Transfer is described in the attached document.
1. 2050873.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
