Is it possible to reference imported CAD files to a relative drive path as might be used with Sharepoint or Onedrive?
Tagged: 19, CAD Imports, designmodeler, mechanical, structural-mechanics
March 17, 2023 at 8:59 amFAQParticipant
In terms of the geometry plug-in there is no setting to setup the behaviour of the CAD file path but there is a possible alternative. When a project is saved workbench creates a file (shortcut) and a folder with the same name (the folder name has _files in the end). Inside this folder there is another one called user_files. If you copy your geometry file to this folder, wherever your ANSYS files archived or copied, the files in this folder are included as well. Therefore, if you import the geometry file from this folder or point to it in the Import in DM for example, that path will remain valid.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
