PCB Design
PCB Design
Is it possible to plot differential group delay with Designer schematic?
    • FAQFAQ
      Participant
      Group Delay for differential lines has not been implemented as a defined quantity to plot but it can be derived by the S-parameters calculation of the differential mode by manually write the output variable: deriv(ang_deg(S(Diff1,Diff2)))/2/pi*1e12
    • Avatarzhengdongliu@o-netcom.com
      Participant
      Is it possible to plot differential group delay with HFSS?
