Tagged: 18.2, General, structural-mechanics, workbench platform
June 5, 2023 at 7:05 am
FAQParticipantNo,currently it is not possible to mirror a mesh using Model assembly. You can transfer meshes from multiple systems to a single system to create an assembly. During transfer, you can rotate or translate geometry, make multiple copies if the mesh, but mirroring is not currently possible
