Is it possible to export my ACP Composite PrepPost surfaces from the generated solid mesh? I wish to use these surfaces to define new laminates or bring into CAD to check assembly clearance, etc.
Tagged: 19, ANSYS Composite PrepPost, General, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantYes. Please see the attached solution document that details the procedure.
1. 2055244.pdf
