Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThe Ansys Viewer file .AVZ is not a standard video format, and thus cannot be embedded into MS PowerPoint. However, if you insert or drag the .AVZ file into a PPT slide, it will appear as an Icon. If the Ansys Viewer is installed on the computer, clicking on the icon will open the viewer.
