June 6, 2022 at 9:58 am
FAQ
ParticipantThe Ansys Viewer file .AVZ is not a standard video format, and thus cannot be embedded into MS PowerPoint. However, if you insert or drag the .AVZ file into a PPT slide, it will appear as an Icon. If the Ansys Viewer is installed on the computer, clicking on the icon will open the viewer.
