Is it possible to define multiple load (Heat generation rate) in table type array parameter using a *DO loop?
June 6, 2022 at 9:58 am
FAQParticipantYes. The following APDL commands demonstrate how to define multiple loads using *do loop;
Fini
/clear
/output,out,out*cfopen,load,txt
*Do,i,1,2*DIM,BF%i%LOAD,TABLE,3,1,1,time,
BF%i%LOAD(1,0) = 0,0.5,1
BF%i%LOAD(1,1) = %i%*10,%i%*20,%i%*30*vwrite,i,i
bfv,%i,hgen,%%BF%iLOAD%%*enddo
*cfclos!create Solid model and mesh it
/prep7mp,kxx,1,50
mp,dens,1,7850
mp,c,1,450et,1,70
block,,10,,1,,1
block,10.1,20.1,,1,,1
esize,.3
vmesh,all/inp,load,txt
/solu
ANTYPE,4
TRNOPT,FULL
LUMPM,0
TIME,1
solve
/post1
/EFACET,1
PLNSOL, TEMP,, 0
