Is it possible to define Cyclic Region between bodies i,.e low boundary and high boundary on two different bodies?
March 17, 2023 at 8:59 am
FAQParticipantYes, it it possible. But the two bodies must be a part of the multi-body part. You may create a multi-body part in both Design Modeler and Space Claim. This is documented in following help manual link. help/wb_sim/ds_cyclic_sym_considerations.html
