General
General
Is it possible to decrease the time required to import the results files into ANSYS nCode DesignLife?
    • FAQFAQ
      Participant
      Yes. By default, the option to view the FE results within DesignLife is active (i.e. “ON”). You can turn that option OFF, which will decrease the import time but prevent viewing the FE results within DesignLife. Note: the time required to import the results files into DesignLife was an issue with early versions of ANSYS nCode DesignLife, but the performance was improved in R18.1.
