Tagged: 19.2, General, structural-mechanics, workbench platform
April 5, 2023 at 2:32 pm
FAQParticipantYes, it is possible. This is the procedure to follow: 1.Open a Workbench session 2.In the upper toolbar click on “Tools” 3.Choose “Options” 4.Select “Regional and Language Options” 5.Choose the language among the ones proposed in the drop-down menu More information is available in the ANSYS documentation: ANSYS Documentation > Workbench > User’s guide > Configuring ANSYS Workbench > Setting ANSYS Workbench Options > Regional and Language Options
