Tagged: 11, General, mapdl, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQ
ParticipantThe /COLOR command can be used to change a line’s color. It is not possible to change the line thickness.
