June 5, 2023 at 7:05 am
FAQ
ParticipantANP Tetrahedron elements are only supported by following Equation of State! Linear Polynomial Shock Porous Compaction P alpha Rigid Hyperelastic User EOS If any EOS other than above mentioned EOS is used then error message pops up
