Tagged: ansys, Control Systems, Designing Embedded Systems, Embedded Software, Embedded Systems, Embedded Systems Programming, Esterel Technologies, How-to (Website Category), Model-based Systems Engineering, Safety Critical Applications, Safety Critical Software, SCADE, SCADE Project, SCADE tutorial
June 3, 2022 at 1:43 pm
Watch & LearnParticipantIn this video, the second in a series of six, we will generalize the median interface with generic types. A generic type is used to refer to a type that is not yet defined at design time. Required in-line implementations will be generated by the code generator for each concrete instantiation type. We will again use the checker and the ANSYS SCADE Suite Simulator to verify that the design is correct and behaves as we want it to, with real type numbers, in this case. We will then add a restriction to our generic type so it can only be bound to numeric types.
- An introduction to DO-178C
- ARINC 661: the standard behind modern cockpit display systems
- Scade One – Bridging the Gap between Model-Based Design and Traditional Programming
- SCADE and STK – Satellite Attitude Control
- Scade One – An Open Model-Based Ecosystem, Ready for MBSE
- Scade One – A Visual Coding Experience
- Introduction to Formal Verification and SCADE Suite Design Verifier
- Using the SCADE Python APIs from your favorite IDE
- Efficient Development of Safe Avionics Software with DO-178C Objectives Using SCADE Suite
- An introduction to space software standards ECSS-E-ST-40 and ECSS-Q-ST-80C
