Tagged: 17.2, fluent, fluid-dynamics, MP - Particle Tracking, post-processing
March 17, 2023 at 1:11 pm
Solution
ParticipantDPM and MRF can be combined to quickly estimate the behavior of particles in moving domains. However, one must be careful when using such models as strong errors can occur when considering relative velocity for particle tracking. These errors can hinder the prediction of erosion/accretion rates of particles on walls, especially for heavier particles as shown on the test case. See attached pdf document for further details.
1. 2046291.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
