Tagged: 2020 R2, Analysis (Q3D), q3d, Remote/Distributed Solving
January 31, 2023 at 9:25 am
FAQParticipant発生ケース リモート解析途中 原因 リモート通信エラーに付随した情報。通信エラーによりパラメトリック解析に失敗 対策 リモートマシンとの回線状況を確認してください
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- [error] Auto Solver Setting is not supported by Manual HPC Settings. というエラーが出て解析できません
