In theory guide, equation 10-9, please clearly express the equation for S_FR(c,f). This is the value represented as PREMIX_CDOT in the flamelet table (not the PDF table).
Tagged: 17.2, Flamelet Models, fluent, fluid-dynamics, Species/Reactions
June 5, 2023 at 7:05 am
FAQParticipantIn equation 10-9, the S_RF(c,f) is the finite rate source term of the progress variable, which is equal to the sum of Arrhenius reaction rates of co + co2 (which is our default progress variable), this is stored as premix_cdot in the flamelet table. This term is evaluated from the flamelet solution of species equations. This is the value before pdf convolution.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
