In steady state, the number of dpm particles in a stream can be measured using ‘strength’, ie: /* mp_dot is the mass source to the continuous phase * (Difference in mass between entry and exit from cell) * multiplied by strength (Number of particles/s in stream) */ mp_dot = (TP_MASS0(tp) – TP_MASS(tp)) * strength; What is the usage for transient DPM?
January 25, 2023 at 7:17 am
FAQParticipantThe parameter “strength” is passed into DEFINE_DPM_SOURCE UDFs. In transient it is the number of particles in a parcel, divided by the solver flow time step. It is used to scale the source term of a single “reference” particle to provide the right source term for all the particles of this parcel. The is designed parameter in such a way that you can use the same UDF for transient and steady simulations without the need to distinguish.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
