In SpaceClaim, why might surface bodies not convert to solids after using Stitch and Gap Tools to remove gaps?
June 6, 2022 at 10:33 am
FAQParticipantThe Gap tool uses default tolerances to find the gap, which might not sufficient to find the gaps and connect the surfaces. If you have already used stitch all the surfaces shown and the Gap tool is not showing any gaps, then try increasing the tolerance. This might help to find more gaps in the surface model and convert surface model into solid.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
