General
General
In Spaceclaim, why might surface bodies didn’t convert into solidafter using stitch and gap Tool despite it didn’t show any gap between surfaces?
    • FAQFAQ
      Participant
      Gap tool uses default tolerances to find the gap, which might not sufficient to find the gaps and connect the surfaces. If you have already used stitch all the surfaces shown and the Gap tool is not showing any gaps, then try increasing the tolerance. This might help to find more gaps in the surface model and convert surface model into solid.
