In SpaceClaim, when I take a section of the assembly, it is not recognizing all parts. How to identify the issue?
June 6, 2022 at 9:58 amFAQParticipant
This may be due to corruption of the geometry. To identify the issue, exit the section mode. In the structure tree, go to the body which was not recognized in section mode. Right click on the body and select ‘Check geometry’ option. This should highlight any corruption in that body. Remove/Repair the corruption.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
