In solving a VOF problem with Coupled Level Set, I click the Surface Tension tab of the Phase Interactions, and find I cannot set the Continuum Surface Force and Continuum Surface Stress surface tension models. Instead, the only options are Wall Adhesion and the value of the surface tension coefficient. How can I restore the surface tension model option?
June 5, 2023 at 7:06 am
FAQParticipantWhen the coupled Level Set option is selected for VOF, a revised surface tension formulation is used internally. CSS/CSF are therefore disabled in the Phase Interactions. The Level Set option is helpful in cases where surface tension effects are strong enough to destabilise the numerics, but offers less customization.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
