Tagged: 18, fluent, fluid-dynamics, MP - Free Surface Flow, Other
June 5, 2023 at 7:06 am
FAQParticipantUsing the TUI command /solve/set/expert answer ‘yes’ to the question “Keep temporary solver memory from being freed?” We want to save the VOF gradient values for post-processing. These values were usually accessed for creating a Contour in the ‘Derivatives’ section In previous versions (up to 17.x), both ‘Derivatives’ and ‘Reconstruction’ sections in Contours display were returning reconstruction gradient filled in SV_VOF_RG. That has been modified in R18 : ‘Reconstruction’ would return SV_VOF_RG if allocated, and ‘Derivatives’ would return SV_VOF_G if allocated. So the proper derivative values for VOF gradients are now available in ‘Reconstruction’ section, then selection for instance ‘Reconstruction dvof/dX’ Corresponding value can be accessed in the TUI (for example) in display / contour / mixture by ‘recon-dvof-dx’
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
