In Mechanical v8.1, why cannot a local Cylindrical coordinate system be used for applying loads or displacements?
Tagged: 17, General, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
Solution
ParticipantPlease refer to the attachment(s) to access the Solution.
1. 321003.pdf
