In frictional contact, why doesn’t the specified keyopt,cid,9,4 to ignore the initial geometrical clearance not help?
June 6, 2022 at 9:58 am
FAQParticipantFor CONTA174 ANSYS Help mentions that ‘The indicated initial gap effect Keyo(9) is considered only when Keyo(12) = 4 or 5. If one is using frictional or frictionless contact then initial gap effect using Keyo(9) may not work. Try to use keyo(5) or define offset in ‘Interface treatment’ option in contact.
