In Fluent, which DEFINE macro can be used to implement a user defined Interfacial Area Concentration (IAC) kernel?
April 5, 2023 at 2:32 pm
FAQParticipantIn principle, IAC applies to all kinds of dispersed flows. This includes droplets in gas droplets in liquid and bubbles in liquid. However the kernels used for break-up and coalescence are only valid for air bubbles in water. To model breakup and coalescence correctly, it is necessary to implement applicable kernels with a UDF DEFINE_PROPERTY is used to modify and implement the IAC kernels.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
