Tagged: fluent, fluid-dynamics, MP - Particle Tracking, multiphase
January 25, 2023 at 7:17 am
FAQParticipantWith the standard Discrete Phase Model (DPM), it is not possible to display locations where the particles are trapped on walls. To be able to display these locations, it is needed to enable the Erosion/Accretion option, in the Discrete Phase Model > Physical Models tab. It won’t change the calculation if no additional setup is added. But it will add the variable Discrete Phase Variable > DPM Accretion Rate availability, which allow to display the Accretion on trapping walls.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
