- All Categories
- Fluids - Postprocessing
- In CFD-Post: When I view my blade in turbo/mprime space, the surface of the blade looks wavy or wrinkled. Is this a problem with the geometry in BladeGen or TurboGrid? Will I have to regenerate the geometry, remesh and rerun the case?
Tagged: 2019 R2, cfd-post, fluid-dynamics, Turbo Post-processing, turbomachinery
March 17, 2023 at 8:59 am
FAQParticipantThe problem is most likely a Post-processing issue. The mapping from cartesian to mprime (turbo) space in Turbo Post requires a background mesh to represent the turbo geometry. For complex or axially long geometries, more nodes may be required for this background mesh to allow an accurate transformation to turbospace. To fix the wrinkles: 1. Go to the Turbo tab and Double-click the affected component under Initialization. 2. There, expand Background Mesh and increase the number of nodes from 2000 to 4000 or more. 3. Plotting should show an improvement in the wiggles
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
