In ANSYS nCode DesignLIfe is it possible to specify a residual stress in a StrainLife (EN) analysis?
Tagged: 19.1, Ansys nCode DesignLife, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantYes, but it must be applied before the elastic-plastic correction. Using the Material Manager, you can directly specify a residual stress value. It will be applied as an elastic stress before the elastic-plastic correction is performed.
