In a sentence: what does the the Discrete Random Walk dispersion model do with the particles trajectories?
March 17, 2023 at 8:59 am
FAQParticipantThe turbulent dispersion model adds a fluctuating component of the fluid velocity to the mean velocity. This affects the particle trajectory through the drag force. The actual distance travelled is obtained by considering all the particle forces and integrating the particle force balance with this updated fluid velocity.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
