Tagged: 2019 R1, Explicit - LS-DYNA, export, lsdyna, mechanical, structural-mechanics
April 13, 2023 at 7:32 am
Solution
ParticipantPlease refer to the attached document to access the solution. Keywords: SPH, Density, CFL Timestep, Sound Speed
1. 2058928_Solution.pdf
