Tagged: 2019 R1, AIM - SYS, Installation/Licensing/Systems, licensing, Other
March 17, 2023 at 9:01 am
FAQ
ParticipantNo, the Discovery Ultimate CPU Core Extension enables AIM to access up to 16 local HPC cores. The Discovery Ultimate CPU Core Extension licenses are not additive, so two Core Extensions licenses on the same machine do not enable 32 cores.
- Q: How do I set the license server from my client machine?
