If “Solve Momentum” is disabled in the Eulerian Wall Film model, is the film velocity still evaluated as non-zero?
June 6, 2022 at 8:33 am
FAQParticipantWhen the “Solve Momentum” is enabled in the Eulerian Wall Film model, the average film velocity is obtained by solving a momentum conservation equation for the film. If the “Solve Momentum” is disabled, the film velocity is evaluated based on two driving forces for the film flow, namely
1. Shear due to external flow: A linear velocity profile is assumed within the film thickness, from wall to air-film interface and zero-jump condition of shear stress is applied to evaluate the film velocity.
2. Gravity force: A parabolic profile is assumed within the film thickness from wall to the air-film interface and the gravity forces is balanced with the wall shear force.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
