If one defines a constant incident pressure at say inlet valve location then will the total pressure will be constant?
Tagged: 19.2, acoustics, incident waves, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQ
ParticipantNo, the total pressure will change since the pressure waves will reflect when there are changes in geometry and pipe cross-section, so we do not expect constant pressure at the valve inlets.
