If a spring is attached to a body with deformable behavior should the displacement of the spring be consistent with the deformation of the body?
March 17, 2023 at 9:00 am
FAQParticipantThe spring displacement is not directly based on the deformation of the body to which the spring is connected. It will be based on the reaction in the spring ( F= Kx) where x is the displacement of the spring.
