I wrote a macro to round a number to the nearest integer. Is there any automatic method to round to the nearest integer in ANSYS?
March 17, 2023 at 8:59 am
FAQParticipantYes, use NINT(x) where x is the number you want to round to the nearest integer. For example, if your number is 10.9… my_number=10.9 my_new_number=NINT(my_number) my_number will be rounded from 10.9 so that my_new_number = 11
