May 15, 2023 at 8:32 am
SolutionParticipantIf the geometry does not touch the centreline, then you can create a full 360deg revolve. If a vertex touches the centreline then you will have to create two 180deg revolve operations. You have the option to combine these two parts into a multibody part after. See attached example.
1. 2053293.zip
