I have two independent/unconnected Static Structural systems in Workbench but I want to see the results for both under the same Mechanical window. How can I do this?
Tagged: 18.2, General, mechanical, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantA and B systems (in image 1) are the original independent systems for which one wants to see the results together in the same Mechanical system. C and D are “dummy” systems used for the viewing results purpose. These will need a geometry to be loaded, any geometry can be used or created. This is just for the purpose of being able to open Mechanical. Before doing this locate the original file.rst files (in image 1). Also go to Tools/Options/Appearance scroll down and pick Beta options. Now double click system C or D to open Mechanical. See image 2. Set this for both systems. Also put in any boundary conditions on both systems or RMB and insert command object. This is just to remove any question marks. Click on Solution for one of the systems and then go to the top to Tools/Read Result Files and find one of the relevant file.rst files and load it. Click the other Solution and repeat the result loading file process. Now you should be able to request any results items under each system. Please keep in mind this is a beta feature.
1. 2053030.zip
