I have ideal gas and floating pressure. When floating pressure reaches 8 bar, I want to open vents, the boundary condition will change to pressure-outlet. How to do this?
April 5, 2023 at 2:32 pm
FAQParticipantWhen the pressure reaches 8 bar, turn off floating operating pressure and enter its value as the operating pressure. Then you can make vent wall as pressure outlet.
- Skewness in ANSYS Meshing
