I have an assembly with several components and would like to save each component as a separate step file in a specific directory. How to do so?
April 5, 2023 at 2:31 pm
FAQ
ParticipantSelect all components in the structure tree, right click – Source – Convert to external. This will save every component as a separate SpaceClaim file in same folder where assembly file is saved. Next, batch converter can be used to convert a group of such files in one format to another. This converter is located in the install directory of spaceclaim and called converter.exe.
