General
General
I have a setup that is based on the tutorial case “closed_homogeneous__particle_aggregation”, but has a longer End Time. Chemkin is hanging before the run can finish and needs to be killed with the Task Manager. What can be causing this?
    • SolutionSolution
      Participant
      Please refer to attachment to access the solution. Keywords: chemkin error, homogeneous, ggregation
      1. 2053062.pdf
