I have a DesignXplorer model that has several hundred What-If design points. Why do I get a message for each design point and have to wait before it solves the next design point?
Tagged: 11, design-exploration, General, Workflow Technologies
March 17, 2023 at 2:15 pm
FAQParticipantThis is a result of having “several hundred design points.” Because the UI part of What-If is written with JScript, this makes things slow, and IE (used to render the UI) is just being cautious about the long time taken by the script to execute. There is no risk associated with this action.
