I found in the manual that the ELBOW command will convert straight PIPE289 elements to ELBOW290 “where it is beneficial”. What are the conditions for when it is considered beneficial?
Tagged: 18, General, mechanical-apdl, modeling-and-meshing, Piping, structural-mechanics
June 5, 2023 at 7:04 am
FAQ
ParticipantUnder the following conditions, pipe to elbow transitioning will done: 1) A straight pipe289 element is next to a curved pipe289 element 2) The section ID’s of the 2 adjacent elements are the same 3) The tangents of the 2 elements at the shared node are within 1 degree. When a transition region is determined, the algorithm marches out along the straight region and converts 289’s to 290’s until a distance of 2 pipe diameters is exceeded. The curved regions will typically have cross-section deformation. We transition these elements so the cross-section deformation can continue into the adjacent straight region.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How to use ANSYS Workbench for Merging Mesh Nodes
- Structural modeling with ANSYS Workbench Mechanical
