I cannot run ACCS and the log file of the extension returns the following error message : Exception has been thrown by the target of an invocation. Traceback (most recent call last): File “”, line 368, in ACCS_Ld_IsValid AttributeError: ‘NoneType’ object has no attribute ‘PropertyValue’
April 5, 2023 at 2:32 pm
FAQ
ParticipantACCS (Ansys Composite Cure Simulation) extension is made to be used with English settings for the language. In the Workbench project page, go to Tools / Options / Regional and language and set the language in English. WB will have to be closed and started again for the modification to be taken into account. The analysis components systems must also be created with Workbench in English (so that the analysis component is named “Transient Thermal” for example).
- How to resolve “Error: Invalid Geometry”?
