I am using the Non-Equilibrium Steam model in CFX. This model has an adjustment parameter called the Condensation Rate Underrelaxation Factor with a default value of 0.2. What does this parameter do? Will it have any effect on the solution?
Tagged: 19.1, cfx, fluid-dynamics, MP - Eulerian MP Flow, NES model, phase-change
April 5, 2023 at 2:32 pm
FAQParticipantThe Condensation Rate Relaxation Factor is an under-relaxation factor applied to the update of the interfacial area concentration for the droplet-continuum phase pair. As with most relaxation factors, it should have no effect on the results over the long term. It is applied to the Interfacial Area Concentration as: IAC_n+1 = URF*IAC_computed_n+1 + (1-URF)*IAC_n where URF represents the Condensation Rate Relaxation Factor
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
